I got my Spark today. It’s fantastic! But there is one thing that concerns me: The download speed to my computer is only 30MB/s. I use the original Pixboom cable and supply power. On the same port I get up to 250MB/S with card readers. I also tried another cable, but no success. 30 MB/s is reeeealy slow…
That speed is definitely not normal. Sounds like your PC is somehow dropping that port down to USB 2.0 speeds instead of full speed. Try plugging it into another computer and see if it makes a difference.
the ssd can go up to USB 3.2 Gen 2x2 20Gbps speeds which is really weird because nobody really uses that, it was a weird fallout usb protocol so most people it will default to 2x1 speeds 10Gbps. you can order a 1-Port USB 20Gbps PCIe Card to use it though, which I would try, and make sure the it’s not the cable having issues
Meanwhile I found the issue. It’s the power device you need to use for the ssd. I used a high speed usb charger, but with a cheap mobile phone charger the speed went up significantly.
Strange. I’ve never had to use a separate power source. I just plug it straight into my MacBook (Thunderbolt 3 port) and get fast transfers.
Does thunderbolt give youv the 20gbps 2x2 speed or 10 I’m curious
Legacy ports often lack sufficient bus power, requiring auxiliary power. Modern Thunderbolt and high-spec USB-C ports easily supply enough power over a single cable.
Macs do not support USB3 2x2 mode.
