Just wanted to share a quick little tip I found today.
Like a few other Spark users, I’ve been a bit confused about how to exit Pre-Recording Mode. While using it today, I accidentally found a neat little trick: when you’re in Pre-Recording Mode, just use the touchscreen and long-press the Record button — that will exit the mode.
I also checked with Pixboom, and they confirmed that this is a usable feature. They said they’ll make this more obvious in the UI in the future, but for now, we can already use this feature.
Hope this helps anyone else who’s been wondering how to get out of Pre-Recording Mode!
Currently, the Spark’s pre-record buffer works as an either/or choice: either the buffer captures the preceding second(s) and saving it stops there, or the buffer is disabled and pressing Record starts a normal recording from that moment — but there’s no way to combine both into a single continuous file.
On cameras like the Nikon Z8 or OM System OM-5, the pre-capture buffer works differently: it runs continuously in the background, and pressing the shutter/record button seamlessly merges the buffered frames with the newly recorded frames intoone continuous clip— the buffered content isn’t a separate save event, it’s simply the beginning of the same recording.
It would be great if the Spark could support this same seamless behavior: pressing Record while the buffer is active would ideally continue recording past the buffered content, rather than only saving the buffer and requiring a separate action to keep recording.
This would be especially valuable for unpredictable subjects (wildlife, sports, spontaneous action) where you can’t precisely time the trigger and want the buffer to flow directly into ongoing recording without a gap or a separate mode switch.
I think this is already how Spark’s pre-record mode works.
With pre-record enabled, hitting Record doesn’t just save the buffer and stop there — it includes the buffered footage and then continues recording from that point. So the seamless “pre-capture into normal recording” behavior you’re describing should already be the default pre-record behavior.
Agreed. Perhaps he needs to check his settings? Pre Record settings now include options of pre-record, buffer and normal recording. Pre record does exactly what he is requesting.
