See my reply here : https://pixboom-community-test.dotnfilm.com/t/external-trigger-options/670/6
Here is the highlights:
Yes, R/S triggering is working, I currently use the Mutiny Power IO via the 3 pin Fischer port. This port has been tested with a Tilta M MK2 unit and the triggering system of a Bolt Robot.
Limited after mart options at this moment.
Waiting for Pixboom to soon release the Web portal access then they do have a whole mobile app planned for down the road. They have not said much about what the Web Portal will do however our guess is some sort of Live View, Controls set, Triggering etc
On my Spark, I enabled wifi and got it to assign me a ip address to my devices however no ports are open so it seems their internal web portal is just not started yet as I would likely have seen a Port 80 or 443 open.
