SSD not mounting on M1 mac
Hi guys! spark is finally here and first tests look epic - the clips are fine on the sdd via camera playback but the SSD won’t mount on my M1 mac/ anyone else had this issue? I don’t see a driver I need to install anywhere. the drive comes up but the partition won’t mount
Thanks,
Al.
still no joy on this and a massive shoot tomorrow morning! please can someone from pixboom reach out asap - this is a shoot we will all want the pixboom to be on.
if i format exfat with my mac I can see the footage on it afterwards but I get an error warning me speed may not be correct and run and cut are really laggy. helppppp
Check this thread out. Maybe there is a solution written for your problem:
Media Will Not Mount / Unable to Download - #12 by manuelwenger
Thanks so much, I will give this a try. I have found that I can read the SSD on a PC so I can at least use it on the shoot. thanks again.
still no joy, won’t mount even after format on pc as per info in link. at least I can get at the data on the ssd with a PC
Hello there,
If you’re on one of our earliest units and having trouble getting the SSD recognized on Mac, we’d suggest reaching out to our support team at service@pixboom.com — our engineers will get you sorted with a firmware update and any technical assistance you need. :raising_hands:
Thanks so much I will do that
Did they fix your issue?
no reply yet but I am sure firmware update will fix it. will report back
Same issue here, it seems to be very random for me. Sometimes it works first try and sometimes it takes a few tries.
A week ago I had a shooting where I no joke tried for 40min to get the ssd to work in my mac. I used the original cable, restarted my mac multiple times and then finally it worked. Luckily there was a delay on set so I had the time.
But for now the ssd recognition seems very random to me.
Thank you!
I’ve found the drive won’t mount on machines that aren’t on Sequoia or later
is this true? i’m on sonoma and it wont mount. itll mount on my mac studio running tahoe
For me I upgraded to 26.5.2 Tahoe and it mounts every time using only one cable - mac m1 pro. Annoying though as I had to do a whole OS upgrade just to use this camera.
Just a quick update… Yes, my laptop was on Sonoma and once I upgrade to Golden Gate, it worked.
