Bolt Robot integration
Hey Everyone! I run a robot rental company in LA and we’re getting asked about our first Pixboom robot job.
Is there an SDK we can browse to see if we can integrate it into our Bolt software? What kind of protocol for remote control is possible? Is there a way to play back the clips over ethernet or even USB-C?
If anyone wants to take this topic off this thread, send me an email buddy@LAcinemarobotics.com
I know there have been several robot guys asking about this type of thing over the months. I’m not sure there’s ever been a good answer regarding this. I’m guessing the forthcoming PC/Mac control over Wi-Fi will address some of this, but I’m not sure if there’s been a timeline or indication of priority for getting that functional.
they responded to me that they are providing one but no schedule yet. you could wire to the trigger pins from the plc of the robot for now
Great topic. For anyone interested in remote control SDK integration, what features would you need most?
For example: remote record start/stop, basic camera settings, playback, etc.
Feel free to share your workflow needs here.
The biggest thing for the bolt is to have accurate run stop to the frame even at 1000fps. We often sync up the runstop dealy with the Bolt dealy and use a Phantom as a proper time measurement device to help calibrate slow motion moves. So having remote playback that I can see the frame numbers to help with timing of fast camera moves is the most important for me.
I would also like a limit recording time feature. So you can set a limit to record only 3 seconds at a time similar to a phantom partition, it will prevent people from forgetting to press stop or having to get too close to the robot when it might not be safe to.
Feel free to message me privately on instagram if its easier. @buddybleckley
Being able to start and stop recording directly from flair is a must-have feature for me when working with a camera.
young
opening it up to semote or third party controllers /apps  would really help.
making your own platform for control is cool - but other controllers exist and dont need too much working out - just integration with your camera and ability to communicate.
what is your thought process in getting people able to communicate remotely with the camera ?
is there a limitation that wont allow ethernet via usb-c to be up and running thats complex ?
is it quicker for you to make your own solution at this time - rather than open up he ports for third party usage ? its tricky to get the cameras out there but as there are a few - there is many requirements for remote usage - on a crane / on a robot / up high - anywhere u cant access the top screen controller easily. I know semote has programmed what it needs to to control the camera - but the port has not been opened up by the FW - surely if your asking what people need does that mean you consider your solution to be quicker than opening up the port so it can be used by whatever remote or APP  that could be made by a third party.
is there a current list of updates your working on and in what order and expected time frame.
I know I have see some short list - but having an exhaustive list may help everyone know what should work and when. many thanks
I have a job in month that i need Rec Start/Stop from flair on my Cinebot Mini. Is this possible yet?
We did a demo day in NYC with a Bolt and they ended up using my Mutiny Power IO with the 3 pin Fischer port to connect up run stop.
The 9 Pin EXT is wired internally different then RED so unless you make up a custom cable you will likely need the Power IO from Mutiny or the Octamas EXT box.
Thanks!
I saw on mutinys site the have the  SPARK POWER IO available, would that do? And then a custom cable?
Yes. I use the power IO.. it comes pre-wired for the Sparks EXT port. Then you just need a 3 pin Fischer cable that fits your triggering system.
I forgot mutiny also makes just the 3 pin to 9 pin RS cable .. SPARK FISCHER 3 R/S INTERFACE PIGTAIL - MUTINY
So you could do this and then you just need that 3 pin Fischer to whatever trigger system you’re using.
