I’m finding on my camera that when I specify the pre-record size limit, its capped at 13-14GB and if I specify more than 14GB, it prints an error on the screen. I thought one of the selling points of the camera was that the buffer size was limited only by the amount of storage you have. Is this expected behavior or is this coming soon or am I doing something wrong here?
No, the buffer is a loop recording—about 2 seconds at the highest speed. Once you press the record button, the rest of the hard drive can be filled—roughly 7 minutes at the highest speed and resolution. It would be a disaster if the entire hard drive were used for buffering; imagine standing out in the woods waiting for something to happen, and then, the moment it finally does, you hit record—only to find the drive is already completely full from the buffer with one shoot… you might as well just go home! ![]()
I mean the way I imagined it working was that I’d have it on buffer mode but then set it to like 30GB so I could record 4-5s of footage. Then, I’d be able to have end-trigger recordings that are as long as I need, but I also wouldn’t burn through 2TB of storage in a clip unless that was something I really wanted.
Is the 2s buffer running on the ssd or is it in RAM in the camera? If it’s the former then I feel like the limit should be increased, and if it’s the latter then I guess the limit can’t be and it’s probably best for the long term survival of the SSD.
As far as I know, the camera has internal RAM, 14 GB of which has been allocated for pre-recording buffering; apparently, it wasn’t possible to implement any more than that—likely because the memory is also needed for other purposes. This was communicated several months ago.
Thanks for the info, I guess that settles it then.
