Sensor / image flip: Yes. We will have a flip option for the live monitoring stream (and playback). We’ve been doing some recent tests on motion‑control / robotic arm setups and understand how important this is when the top screen ends up inverted in certain rig orientations.
“REAL” log: Could you clarify what you mean by “REAL”?
SDI triggering: Our SDI is one‑way output only; it does not accept command input for roll / cut. You can control the camera via other interfaces (e.g. the EXT port).
Power: Yes—mains power and V‑Lock are supported, with automatic switching / seamless changeover.
1800 fps: That mode uses a crop. For exact resolution / frame rate combinations, please check the “Explore the Performance Modes” section on the homepage (As shown in the red dotted box in the figure below).
Recording: It is the Pixboom RAW solution—our own recording method.
So just to be clear the 2K modes aren’t lineskipped with aliasing/moire? That’s a bad thing with the Freefly Wave. The Wave lineskips in their 2K mode and looks really soft with heavy moire and aliasing.
Correct—Spark’s 2K mode is not line‑skipped; it uses a sensor crop. So you won’t get the soft look or heavy moiré/aliasing. The trade‑off is a reduced field of view.
Great! Thanks for the info Young! Yeah, I don’t mind the reduced field of view. It’s actually helpful to me when shooting wildlife since I need the added crop! hehe
