Hi,
I was wondering what the exact dimensions of the top screen area are, as I’d like to get a screen protector cut to avoid scratches.
-Christian
Hi,
-Christian
Hey Christian!
Regarding the top screen, the actual active display area (the part that lights up, excluding the bezel) is 77.76mm (H) × 43.74mm (V).
I’d recommend cutting the protector just a tiny bit larger than those dimensions—it usually makes alignment and application a lot easier. Hope that helps!
Hi, thanks for your reply. I meant including the bezel, so the entire “glossy” surface is covered.
Ah, gotcha!
If you’re looking to cover the entire glossy surface, the full dimensions are 84.16mm × 59.14mm."
Thank you! ![]()
