Formating SSD on MAC OS is possible* contrary to the manual
I formatted the SSD on my MacOS and after that I was having errors on camera.
Formatting inside the camera did not solve the issue.
Then i noticed this manual part:
“*Do not use macOS for formatting, as it does not support the required 16MB allocation unit size and may cause severe recording speed degradation.”
However you can do this 16MB allocation via terminal on MacOS. ChatGPT helped with exact command lines and it worked. No more Errors on the camera and everything works again.
