List of Available Spark Accessories
I figured it would be good to have a list of accessories that are available for the Spark. Let me know if you’ve seen anything that should be added.
Power and I/O
Mutiny Spark Power IO - available in gold mount and v mount, this plate adds D-tap, 2-pin, and a 3-pin Fischer R/S power ports along with a 5-pin timecode, BNC genlock, 4-pin UART/GPO, 9-pin accessory passthrough, and DC in ports along with a record button.
Mutiny AC/DC Power Supply - Available as both an AC power supply as well as a battery block compatible XLR cable.
Mid49 Gold Mount and V-Mount Power Plates - Available in gold mount and v-mount, this plate expands the power port options with one 5V USB-C, two D-taps, two 2-pin, and two 3-pin Fischer R/S power ports, as well as a 4-pin XLR power input. The power plate will automatically switch from DC to battery if the voltage drops below 12.5v (or if power is pulled completely).
Octamas Power Box Pro IO Micro - Available in both gold mount and V-Mount, this goes directly onto the Spark’s built in V-Mount and gives power and IO options: 9-pin EXT in (using RED to Pixboom adapter cable), 9-pin RED EXT passthrough (compatible with RED DSMC3 accessories), 3-pin 24V Fischer R/S, 6-pin RED DC power input, 4-pin RED CTRL (reserved for future functionality), two 2-pin power, 5-pin timecode/genlock, BNC genlock, and two D-taps.
Octamas Power Distribution Box IO - Loses some of the power options of the Power Box Pro IO (no battery plate, no DC in, no D-tap, 3-pin Fischer is 12V instead of 24V), this uses a 2-pin 12V power input and is designed to be mounted onto the side of the camera or on a cheeseplate rather than the V-mount on the back of the camera.
Cables and Expansion
Mutiny Bolt-on R/S Button - “BOLT-ON R/S record button (run/stop trigger) for the Pixboom Spark cameras. Our button uses the 9pin EXT port on the camera or on our SPARK Power IO box. Our 9pin features a re-keyed keyway so that the DC in port, USB-C and HDMI connectors are un-obstructed. The Bolt-On R/S button lets you easily add a record button where you want it. Mount it on a handle. Mount it on a shoulder rig. Mount it 250 feet away using standard 1/8 (3.5mm) headphone extension cable.”
Mutiny Antenna - basic mini antenna for the Wi-Fi port
Ignite Digi Pixboom EXT to RED EXT Adapter Cable - This cable allows the use of existing PIXBOOM Spark’s EXT port uses the same lemo BUT has a different pin-out than RED DSMC3 EXT port. This cable bridges the gap, meaning you can use any RED EXT Breakout.
Ignite Digi D-Tap to Spark Power Cable - Powers the Spark via D-tap.
Ignite Digi 3-Pin Fischer to 9-Pin EXT Cable - Connect any 3-pin Fischer cable to the Spark’s 9-pin EXT. Does not provide power to the accessory.
Ignite Digi 3-Pin LEMO to Spark Power Cable - This 3-Pin Lemo Right Angle to 5-Pin Lemo Right Angle cable is designed to feed hot-swappable, regulated 15V from these Ignite accessories: TB50 Hammerhead, TB51 Hammerhead, Power Expansion Pack for MōVI Pro, and Power Expansion Pack for MōVI XL.
Ignite Digi TPEP to Spark Power Cable - This 3-Pin Lemo Straight to 5-Pin Lemo Right Angle cable is designed to feed 15V power from 3-Pin Lemo on the TORQ Power Expansion Pack (TPEP) to PIXBOOM Spark!
Ignite Digi Ronin 2 to Spark Power Cable - This 6-Pin Lemo Straight to 5-Pin Right Angle cable is designed to feed power from Ronin 2 to PIXBOOM Spark. Source regulated 14.4V from the DC-OUT Lemo, located on the underside of the gimbal cage.
Ignite Digi Titan LT to Spark Power Cable - This 2-Pin Lemo Straight to 5-Pin Lemo Right Angle cable is designed to feed 14.4V from TITAN LT to PIXBOOM Spark. Plugs into the 2-Pin Lemo 14.4V port on the tilt stage unit on TITAN LT.
Alvin’s Cables Yongnuo to Spark Trigger Cable - This interfaces between the 2.5mm connection on the Yongnuo RF-603 II trigger for remote camera record start/stop control and the Spark. Uses a right angle TRS plug and 9-pin non-rotatable EXT plug.
Alvin’s Cables 3-pin R/S to Spark Adapter Cable - Provides a 3.9" connection between a Fischer 3-pin R/S interface and has a rotatable, right angle 9-pin EXT.
Alvin’s Cables DJI Focus Pro to Spark R/S Cable - Allows for triggering runs/stop from the USB-C port of the DJI Focus Pro motor when using the Focus Pro Grip.
Cages, Plates and Risers
Mid49 15mm Lightweight Riser Plate - Baseline 15mm LW (Pixboom Spark) is a baseplate that holds 15mm lightweight rods at the correct distance from the center of the lens and has an Arri dovetail compatible slot on the bottom while the top section uses an Arca Swiss plate.
Bright Tangerine Leftfield Mini Baseplate Riser - This Arri dovetail compatible baseplate comes with a 52.5-55.5mm riser plate, perfect for getting a cageless (or at least no bottom plate) Spark to proper 15mm lightweight height. The 2-stage release lever allows for both sliding off a dovetail or lifting straight off.
Putting a bottom plate on the camera? Get the 61.5-63.5mm riser kit version for proper height (also available as a stand-alone riser if you already have a Leftfield Mini baseplate). I’d also suggest getting the Rear Rod Bracket expansion.
Octamas Base Cage Set - Includes bottom plate riser with 15mm lightweight rod support and top plate with handle.
Octamas Advanced Power IO Cage Set - Includes an advanced bottom plate riser with built in power distribution: D-tap, 2-pin power in, two 2-pin power out, 5-pin timecode and genlock, 3-pin 12v Fischer R/S, and 9-pin EXT (wired for DSMC3, so needs to use the Spark to DSMC3 cable adapter). Also has additional side cheese plates and mounting points over the Base Cage.
Octamas Full Power IO Cage Set - Appears to include everything from the Advanced Power IO Cage (immediately above) plus the Power Box Pro IO Micro (Power and I/O section at top).
Mutiny Plate - Make your own basic cage with the modular rib plates. It works as a top and/or AC side plate (it does not work with the operator side since it would block the media door). These let you keep a super stripped down camera while also providing some additional mounting points.
Mutiny Pro Cage System - Includes a top front plate, top rear plate, and side plates giving lots of mounting points along the sides (not just in the “rib” area). This does not come with a bottom plate. The front top plate is tapped on the front for mounting future accessories, and the rear plate is tapped for the “still in development” I/O locking brace, which securely locks their I/O battery plate in place.
SmallRig Spark Cage - Included with Kickstarter orders, this includes a bottom plate, NATO rail side ribs (compatible with SmallRig’s HawkLock system) with 1/4"-20 and 3/8" holes, and a NATO/HawkLock top rail. The insides are rubber padded to protect the camera body from scratches and the threaded holes have solid bottoms so bolts can’t pass through and damage the camera. Currently not offered separately from the Kickstarter rewards.
Ignite Digi Keystone - A square cage to keep the camera centered for easy vertical/horizontal rigging, the Keystone integrates into Ignite Digi’s existing ecosystem of power distribution, mounts, plates, and other rigging accessories. It is also designed to work with the Arri Alexa Mini/Mini LF mounting ecosystem (such as the MAP-2, BUD-3 and CCH-2).
Lens Mounts
C7 Adapters RF Mount - Positive lock RF mount with no electronics (manual lenses only).
C7 Adapters L Mount - Positive lock L mount with no electronics (manual lenses only).
C7 Adapters LPL Mount - Positive lock LPL mount with no electronics (no LDS/LDS2 support).
Ignite digi is also making a cage for the pixboom according to their social media.
Hi thanks for this list of accessories
The Tilta quick release base plate for Sony FX6 plates is fitting with the small rig cage
Do you have a photo of this? Thanks!
With the tilta plate you can not keep the Arri rosette but work fine and cheapest solution for now
Many thanks for the pictures and clarification!
The C7 RF adaptor.. Explain no electronics. For aperture for example you would have to throw that lens on a canon body, set the aperture, take lens off and mount to the Spark? Im referring to the Canon RF range non-cinema.
I’m guessing it means you can only use RF mount cinema style lenses, which makes it not very useful. C7 makes good adapters, but I think they really dropped the ball by not including any electronics.
Looks like Mutiny’s cage is coming in two days.
Looks like they couldn’t wait. Mutiny cage is now available: PIXBOOM SPARK PRO CAGE - MUTINY
If you only want some basic side and/or top plates, you can buy those instead of the full cage option: PIXBOOM SPARK PLATE - MUTINY
Apparently, after a certain amount of time, the ability to edit posts is removed, so I’m unable to update the first post. @admin, is this a forum software setting that can be changed? Otherwise, it’s difficult to keep this kind of topic updated and useful as new accessories come out.
Hi there,
it should be sorted now — please give it another try and let us know if you’re still having trouble! :blush:
Thanks, I’m able to edit/update the original post again.
Added the new Ignite Digi Keystone cage.
KEYSTONE for PIXBOOM Spark – Ignite Digi
Appreciate the effort you put in mate to keep us organised and up to date!
Thank you buddy!
Added some new things from Alvin’s cables:
  • R/S cable for Yongnuo RF-603 II trigger
  • Standard 3-pin R/S to EXT adapter
  • DJI Focus Pro R/S cable
