Hello, I am about to test a pre release Pixboom on FPV tomorrow. Can a dev please provide me with the pinout for the runs stop control so we can trigger in the air
R/S trigger from EXT works on most units - however it might not be enabled depending on the camera FW version. If you can see a GPIO item in the menu, under SYSTEM, then it can be enabled.
It’s worth mentioning that early demo units didn’t have a pull-up on pin 6, so these require an external pull-up to avoid inconsistent behavior.
Shorting Pin 6 to GND from the EXT breakout cable will trigger START/STOP, provided the R/S option is activated in the GPIO menu.
-A
Many thanks! We didn’t get chance to do this in the end but as soon as I have mine it will be going in the air
