Can you tell us about power consumption, how long will a 98wh battery last when the camera is powered on and idle, and how long it will last when recording, perhaps you could test max resolution and frame rate and then a lower resolution aswell. Thanks
The maximum power consumption of the Spark is around 43W. With a 98Wh battery, you can expect it to last for over 2 hours.
