Hi, I’m curious, what resolutions does the Spark support? 4K, 2K, or even lower (to achieve higher frame rates)? Also, can users customize the resolution, like with some industrial high-speed cameras?
Hi Coco,Yes, we support resolutions like 4K, 2K, 1080p, and 720p! This flexibility allows you to achieve higher frame rates by opting for lower resolutions. As for custom resolutions, it’s indeed an intriguing topic. From what we know, few cameras currently offer configurations for custom resolutions. What are your thoughts on this?![]()
What’s the framerate at 1080P and 720P?
The frame rate at 720P will be >2600fps.
Thank you! That’s an amazing frame rate for 720P! How about 480P and 360P?
Absolutely! We’ll support both resolutions, with frame rates getting a serious upgrade. The full resolution@frame rate chart will be released after final testing—exciting details are on the way! Be patient. ![]()
可以设置更低的分辨率可太酷了!正常来说我们拍摄食物素材需要2k以上分辨率来获得更好的画质,但是有些时间我们需要更高帧率来获得更慢的画面,这种情况下牺牲一些分辨率是可以的。
It’s true the framing is offered by phantom series and others from vision research along with Photron, I believe freefly do it too, but there isn’t a major benefit to there’s, unless you are using the unit it for scientific research it i dont think it has a genuinely usable image, I am a tabletop director and own the phantom gold, it’s not a feature I would miss on the spark, I’d be much more interested in futures such as cine file output with 12bit color, (14 is nicer but 12 is plenty.
