What is the remote trigger option for the camera?
i tried connecting to WiFi and using the IP address to get to a web portal but none of the ports 0-1000 are open.
is there a way to connect with USB that works?
urgent, please help
urgent, please help
This WiFi remote via a Web portal is supposed to be enabled in the next firmware update due soon.
USB cannot be used for remote Run/Stop and there are no plans for that yet.
I use a physical cable trigger from Mutiny via the EXT port for run/stop at the moment. This trigger cable can be extended in length using standard 3.5 audio cable extensions.
Latest firmware is up! WiFi remote is working now and includes Live View and Playback.
I haven’t tested it extensively yet but looks good so far!
