I see articles that say the SDI will output 12G. Is there also options to change the output to 1080? As well, what’s the max FPS in the SDI will be able to output in 1080 and 4K?
Yes, there will be options to adjust the SDI output resolution. The maximum frame rate for both 1080 and 4K output via SDI is 60fps.
Will there be higher output frame rates from HDMI or will they be the same?
The HDMI output resolution and frame rate for Spark are the same as the 12G SDI output, supporting up to 4K at 60fps.
