It may not be a “bug” exactly, but a bad practice. I did the firmware update and, as part of performing that update, we have to factory reset the camera. This deletes all the custom sensor resolution settings, white balance settings, and any other settings I had saved, wiping everything back to factory. If this is going to be a necessary thing every time, then we need a way to save our settings so we can simply import them again after these upgrades and factory resets.
100% agree a profile save menu is required not only for firmware updating but daily use within a rental environment. The camera would get defaulted each time it returned from a job and any DP that uses it would want to save his own profile settings for quick reload.
I came here to highlight the exact same issue that Austin outlined when shooting with my Sony lenses, and to suggest exactly the same control implementation in new firmware allowing you to select ISO or SHUTTER / ISO using FN1 and FN2 buttons and then be able to alter them DURING A TAKE using the scroll wheel, not just the FN buttons. We need to be able to adjust electronic irises whilst recording, especially on lenses that do not have a physical iris ring. I would also like to echo the problem of not being able to disengage prerecord mode without recording a clip.
If there is enough processing power left, it would also be handy to have the option of zebras or false colour (arri type, spectrum type, custom) on the live screen as well as a center marker, if possible. Also, the camera demonstrates on its lens page that it is conscious of the focus throw position. Please could we have the option of a focus distance readout on the live screen in future firmware? These are all nice-to-have’s, and not essential by any means.
Please could Pixboom comment as to if there are plans by them to produce a strong and secure camera handle that makes use of the included pogo pins on the Spark body to hopefully give us some more assignable dial controls that could be assigned to Iris, Shutter etc. in addition to a record trigger - even better, how about a smoothly designed wheel that gives precise electronic manual control of focus with electronic mount “focus by wire” lenses, a bit like we get with DJI gimbals when paired with some Sony cameras?
Obviously this handle will render the current Smallrig cage useless as it covers the pogo pins, so we would also need a suitable cage replacement / modded part that allows for use of this new handle. Perhaps Pixboom’s handle could be designed along the lines of the RED Komodo Outrigger handle, but with some clever assignable dial additions. One essential aspect of the design is that if the handle attaches where the current NATO rail resides, as with RED’s handles, the new handle needs to include that NATO functionality so that we can attach top handles / monitors in exactly the same way we currently do with the Smallrig cage without the side handle, IE it must not affect our ability to add other accessories on the top of the camera. Pixboom could even produce a NATO top handle specifically for the Spark that obstructs the top screen as little as possible, as most current NATO top handles will obscure part of the screen. If they do so, it would be great to include a circular spirit level in the handle as well as another NATO rail integrated into that top handle, for adding a NATO monitor mount and other accessories securely.
One last suggestion for future firmware is to include a clip marker option whereby on completion of a good take, you can select to mark it as a starred clip so that when you come to offload the media in Pixboom Cine software, the good clips are already highlighted and easier to identify. But this is a much less important addition, and just an additional idea!
I’d also still like to see Pixboom produce a cover to help protect the Spark’s SDI, HDMI, EXT ports etc. at the rear of the camera, even if charged as an extra. Many thanks.
Thank you for sharing this!
Our technical team will check and confirm what’s happening here. From the description and the extreme crop setting, it looks like it may be a small software bug rather than a lens issue.
We’ll look into it and keep it on our list for review.
Yes, absolutely — we completely agree! We’ve already added this to our feature request list.
Thank you for your detailed suggestions. I have already replied to you in your other post, so please check it there.
A slight bug that has shown up when updating is confusing to most as well.
When updating the firmware the Spark will show the Update Button above the Soft defined button, We are then instructed to hold the update button for 5 secs and when pressing the soft defined hardware button, nothing happens, To complete the firmware update you MUST press and hold on the screen UPDATE to get the countdown to start and complete the update.
Either we need to update the instructions or the hardware button needs to be enabled for this function.
Thanks Young!
I figured I’d put together a running list collecting all the issues and suggestions into one reply so people don’t have to scroll through everything (plus I’ve included other things suggested in other threads). I tried to organize them in some way by topic and add notes about issues that have been acknowledged and addressed by Pixboom (I put these notes in italics). Apologies if I’ve missed an issue or a Pixboom followup on a topic. Here we go:
Hardware
- SDI output not working. This is currently a top priority engineering is working on. ETA, July 2026.
Menus/Interface/Buttons
Pixboom has said they’re redesigning the Live View interface, which may address many of these things.
- MENU/BACK hard button not working on Live screen
- Inconsistent scroll wheel functionality across settings and menus
- Inconsistent hard button/soft button functionality (sometimes one works while the corresponding other button doesn’t)
- MENU/BACK hard button works inconsistently across menus
- Menu driven iris changes can only be made on the Home Screen, so I can’t see the Live view while making the changes (using the built in screen). See Live View interface update link above.
- Fn1 and Fn2 buttons don’t change settings while rolling
- Settings changes (such as iris stops) don’t take effect until after selecting the value we want and then also selecting “Set,” which makes it cumbersome to scroll through and test how they change the picture. The settings should change as soon as we tap a new value and not make us also tap “Set.”
- Scroll wheel not able to change settings after pushing a Fn1/2 button. Request noted and being evaluated.
- Custom settings lost when updating firmware (which requires a factory reset). No way to save/export user settings. Pixboom said they’d fix this.
Monitoring
- No LOG output. Currently being discussed between Young and users.
- No exposure tools
- Plugging in HDMI after booting up can cause the camera to cease working (requires power cycling)
- Some issues with sending a 4K image (switching to 1080P works)
- No 24Hz option
Media
- Camera boot up time without media installed takes 3.5 minutes and gives an error message
- Can not change camera letter or roll number (stuck at A001)
- No “eject media” function (despite camera door saying to eject beforehand)
- Hot swapping media without powering down locks up camera
Image Quality
- Sensor stitch line showing up for some users (could potentially be fixed with a manual black shade option in the software). Pixboom engineering is looking into the problematic cameras.
- Blue/Yellow bands at top and bottom of extremely cropped sensors (low resolutions like 256x32). Engineering is looking into this.
User Manual
- No documentation on proper media ejecting practices
- Manual incorrectly lists lens mount screws as 3.0mm hex, but is actually T8 Torx. Will be fixed in the next user manual update.
Pixboom Cine Software
- No ability to export non-LUT footage expect for DNG format. Currently being discussed between Young and users.
- No hot key support for setting in/out points, etc.
- No ProRes or H.265 export support on Windows. This is being looked into.
- Export frame rate resets to 24fps every time the program is opened. This should be a perpetual setting, so Europeans can select 25fps and it’ll stay that way until they change it. Possibly being fixed, see above link.
- No exposure tools. In roadmap discussions. Again, see previous link.
- No way to reset/clear in/out points in a clip when they’ve already been set (if I’m understanding point 1 correctly)
Feature requests
- Additional anamorphic desqueeze ratios (such as 1.8x or vertical desqueeze). Young has hinted there will be more options coming up.
- Auto fan speed control (camera will speed up or slow down the fan automatically, depending on temperature)
- Ability to change playback behavior (loop same clip, automatically advance to next clip, etc.)
- Ability to mark “good takes” in camera
- Ability to add center markers to monitoring
- Ability to adjust iris while rolling
- Auto white balance. Suggestion noted for consideration.
- In camera custom LUT support
- Better (or custom) “user” resolution names. Either let us type in a custom name (such as “3.8K 16x9 3820x2160"” or “2K 2.4:1 2048x853”, etc.) or at the very least have the default “User” title also include the aspect ratio (such as “User 1.78 3820x2160,” “User 2.40 2048x853,” etc.). Right now it’s just “User” and the resolution, so then I have to do the math to figure out the aspect ratio when scrolling the list.
- DaVinci Resolve native PXBC support
- Remote control SDK. Young has asked for input on workflows.
- Flair integration for robot arms
- Record limit setting (to stop rolling after a predetermined amount of time - useful in case somebody forgets to cut)
- CAD, 3D models, or technical drawings of camera hardware so people can model and design accessories. Include wiring diagrams for pinouts for cable design.
- Ability to send an overlay feed with relevant camera data to an external monitor. Maybe have 3 settings: clean, basic (record tally light and maybe a couple basic things like timecode, card time/space remaining, clip number - just the things video village might need to see) and advanced (all the settings like iris, shutter, iso, etc. Maybe these can be customized by the user on what items they want included).
- Ability to record proxy files in camera. Pixboom is looking into whether this is possible on the hardware.
Upcoming features in active development
- 12-bit recording mode (cuts frame rates approximately in half)
- Enabling SDI
- Mobile/Web app
- ProRes recording
Fixed
- Anamorphic desqueeze “radio” fixed to “ratio” (v1.0.1)
- 4K over HDMI enabled (v1.0.1)
Yea, I would love it if Admin can pin this as a permanent post … then we all just submit to it and get this running to be the offical tally of requests and fixed items.
I was using my camera today and powered it up before plugging in the HDMI. Upon plugging it into my SmallHD Cine 13, no image came up on my monitor and the screen on the Pixboom slowly faded to black and the camera froze up. I power cycled it (plugging in the HDMI before booting up this time) and it worked fine. Wanting to see if that glitch was a one-time event or not, I powered down the camera, unplugged the HDMI, and powered back up without the HDMI plugged in (to recreate the initial circumstances). Once fully booted, I again plugged in the HDMI and again the monitor did not get an image and the Pixboom screen slowly faded to black as it did before, so this is a repeatable problem (just one extra data point, this was all done with the output set to 3840x2160 60p).
I also had an issue where one time the monitor wasn’t getting a signal in 4K mode after booting up (the monitor plugged in this time, so no issues with the Pixboom screen fading to black as noted above), but when I switched to 1080 suddenly the monitor worked. Going back to 4K I lost picture again. So I rebooted the camera and then 4K HDMI worked again. This was all with my Cine 13 (supports 4K) and a new HDMI cable that supports up to 8K.
It would likely be helpful to them if you can send over a picture of what was plugged into the camera and how things were routed at the time.
I will try and repeat your issue with my body as well.
It was literally just the camera plugged straight into the Cine 13. I was using a big monitor instead of an onboard so I could check focus easier as I shimmed my new PL mount.
Ok, so it was an off-board monitor not sharing power, only a HDMI cable… about how long was the cable?
6 foot HDMI, so pretty short.
