4 TB and all framerates would be better If I remember right, Freefly Ember offers two options:
2.5TB with prerecord and 4 TB without prerecord and all speeds and framrates. But the Codec is ProRes LT.
Are you adding ProRes to the camera? Maybe ProRes LT will allow lower datarates then raw, making it possible to use all framerates on a 8TB SSD with a LOG profile and User LUTs?
Yes, you’re absolutely correct. We plan to support the ProRes series in the future, but not at launch—it will be added later through a firmware update. At that time, due to the lower bitrate, it will be possible to use storage cards with other capacities. At launch, if you urgently need larger capacity storage cards, the option is to work with half the frame rate.
Yes, because third-party SSDs should be able to match the bandwidth requirements at lower bitrates. However, there might be some stability issues with third-party SSDs, depending on their quality control.
The write endurance of the flash used in the 2.5 TB module is 42,000 TBW. This ensures long-term reliability and durability for high-performance applications.
