Video output from SDI n HDMI
Hi,
Understand there are HDMI and SDI outputs. Would both outputs work together for video monitoring or it would be either or? Also what’s the video out resolutions from the ports?
Yes, both the HDMI and SDI outputs can work simultaneously for video monitoring. The output resolution for both ports is 4K.Hope this helps!
hi,
when you say the output is 4k , is it not possible to have it in 1080P ?
for example the SDI in 4k and the hdmi in 1080P
